603,813 active members*
2,930 visitors online*
Results 1 to 4 of 4
    Sep 2003
    1490
    Question Mach 3 Wizards Z Start Setting
    Hey I'm ready to cut but want to drill a hole through my work table.
    When you use the Wizards in Mach 3 such as circle cut and hole drill, do you position the Z axis down and just kiss the surface to be cut then press the Zero axis button and then Press Start??
    Jan 2005
    2010
    I always use either paper (maybe even a cigarette paper) or a shim stock and come down till I detect friction and then punch a Z+ dimension equal to the measured thickness of the "feeler gauge".
    Just for safety sake I usually punch in a step jog value and jog Z up, reset zero and try a "dry run" and then jog back down then "GO".
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    Sep 2003
    1490
    Quote Originally Posted by jhowelb View Post
    Sounds like that is a Yes, jog down until I touch the paper, then Zero the "Z" and key in +0.004" for the paper Correct? You didn't mention Zero the "Z" but I think you implied it.
    Hey you are dealing with a rookie here. He He
    Jan 2005
    2010
    Actually, when you key in a value, that sets zero. No need to first zero then key in the value. If you do a dry run remember all the resetting you gotta do to bring everything back into compliance.
    Wish I could put "hands on" to demo exactly what I'm saying.
    Cheers!!
    PS: I routinely bring all axis close to zeros and reference all to home before I set ANYTHING! That prevents the machine from doing something crazy!
  1. re jog tab in mach 3 when in wizards
    By woffler in forum Mach Wizards, Macros, & Addons
    Last Post: 02-08-2008, 03:14 AM
  2. mach 3 wizards, "write"
    By 300sniper in forum Mach Mill
    Last Post: 01-22-2008, 02:13 AM
  3. Setting Up an X3 in Mach
    By bryanrabb in forum Benchtop Machines
    Last Post: 08-01-2007, 01:48 AM
  4. Mach 3 Wizards- Metric mm possible ?
    By ASlater in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2006, 02:25 PM
  5. are wizards included in license ver of mach
    By Gads in forum Mach Software (ArtSoft software)
    Last Post: 03-28-2006, 01:08 AM
