603,836 active members*
3,228 visitors online*
    Jun 2005
    180
    Mach 3 Write Wizard
    I have used the write in Mach 2 & it works fine, but when I tried it in Mach 3, the G code has zeros in it for the X and Y positions. (The letter height is set at 1").
    I must be doing something stupid -- any suggestions?
    Mar 2003
    35494
    Did you pick a font? I had the same problem the first time I tried it. Most likely you haven't checked one of the necessary boxes or buttons.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2005
    180
    I picked a font, but when I went back for one more try, I found that the direction was not checked. Now it works. I think in Mach 2 it defaults to 0 degrees, but in this version there is no default.
