603,978 active members*
2,216 visitors online*
Results 1 to 8 of 8
    May 2016
    15
    Mach 4 breakout / controller board reccomendations
    Can anyone recommend any breakout / controller boards for Mach4 that they have been really pleased with?
    Thankd
    Adam
    Jun 2014
    777
    Re: Mach 4 breakout / controller board reccomendations
    Is Mach 4 fully functional now?
    3axis go for uccnc and a uc400 motion controller. Better than Mach imo.
    May 2016
    15
    Thanks Jon. I'm working with a clean slate for cutting soft metals. Planing on a gantry design with a 24x24" working area and about a 5" Z axis. Do you recommend any other control hardware to go with this? Any preferred supplier?
    All the best,
    Adam
    Dec 2006
    108
    I'm using the PMDX 411 controller which is a USB to Parallel configuration which I'm pleased with. When I rebuild my control box, I will probably go with one of there other solutions that is USB to USB.
    Best Regards.
    Carl
    Jun 2015
    943
    Get a UC400ETH and UCCNC, it is much smoother and more reliable than Mach and even cheaper.
    Jun 2014
    777
    Quote Originally Posted by ahacking View Post
    All the best,
    Adam
    Sounds like you would be better of building a vertical mill or fixed gantry moving bed cnc or retrofitting a manual mill.
    Depends what budget you have.
    Jun 2014
    777
    Quote Originally Posted by OlfCNC View Post
    Hijacking the thread here but olf I have a uc400 on its way, and currently running 2 other machines on uc300. Don't suppose you have tried both and know if the Ethernet uc400 behaves much differently to the uc300 usb?
    Jun 2015
    943
    Jon, this thread was posted in the uccnc forum, seems like a moderator relocated it.
    I do not have a UC300, only a UC100 and a UC400ETH, they seems to work the same. but with the ethernet I could get a 25meters connection to my control PC without issues which is great as my plasma machine is large and I don't like the control PC close to the plasma source and the plasma dust which is really nasty stuff.
  1. Wiring mach3 breakout Board BL-Mach-v1.1 D402
    By CNDaniel in forum Mach Software (ArtSoft software)
    Last Post: 06-19-2018, 02:54 AM
  2. Need help, Mach 3 breakout board upgrade!!
    By Wgarner1414 in forum CNC Machine Related Electronics
    Last Post: 05-03-2016, 05:58 PM
  3. Wiring mach3 breakout Board BL-Mach-v1.1 D402
    By Mark14 in forum CNC Machine Related Electronics
    Last Post: 02-21-2015, 11:21 AM
  4. MACH 3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
    By Robiz in forum News Announcements
    Last Post: 08-30-2011, 03:10 AM
  5. breakout board suggestions for mach and lathe
    By panaceabea in forum Mach Lathe
    Last Post: 12-15-2007, 10:20 PM
