603,864 active members*
5,326 visitors online*
Results 1 to 8 of 8
    Dec 2016
    9
    Mach 4 Stepper configurarion. Help Please!
    Hoping for some help configuring settings in Mach 4 for my steppers. This is my first attempt at this type of system, so bear with me...
    Basically, my problem is that I can't get Mach to control the motors.
    Here's what I'm working with:
    -Mach 4 Version 3233 (demo mode - will purchase when I know it will actually work)
    -Warp9 ESS V2
    -C10 Break out board
    -Keling 600-48 Power Supply (running 110V)
    -1 Keling 8060 Driver for my 906 oz motor
    -2 Keling 5056 Drivers for my 570 oz motors
    Mach definitely IS communicating with the ESS and BOB because the 1 motor I have connected turns constantly as soon as Mach is opened and shuts off when I close out of the program. (the motor also gets super HOT which is a bit concerning!)
    I've triple checked all connections (wires) against the diagrams for every component and i believe they're all correct. Ive also read thru the Mach 4 docs and instructions as well as the ESS docs and I'm definitely missing something...
    One thing that I can't seem to get any real info on is how to configure the dip switches on the drivers. The factory setting is all on. I have not changed them.
    Maybe someone out there has some advice? or who knows...
    Thanks for reading. Any and all advice is very much appreciated!
    Bob
    Dec 2016
    9
    Re: Mach 4 Stepper configurarion. Help Please!
    Ok, So I got the dip switch information from the manufacturer. Motor not running on its own anymore and not getting crazy hot. Not just need to get them to turn when I want them to...
    Could it have anything to do with my PC? Toshiba laptop running windows 10. 64Bit. 8GB Ram...
    Thanks again1
    -Bob
    Sep 2009
    1856
    Does the C10 need a Enable signal on the steppers or the drive
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Dec 2016
    9
    Turns out the C10 needs the enable signal. and its EXACTLY what I missed.. Looks like Daniellyall is a genious!
    Thanks!
    Sep 2009
    1856
    Na you're not the first with that set up C10 and ESS. I need the same thing with my MB06V2
    [SIGPIC][/SIGPIC]
    Dec 2016
    9
    Hoping for some more advice.. turns out there's not a ton of info on Mach 4 and it's just different enough that the Mach 3 stuff doesn't quite carry over
    Here's what i'm still having trouble with:
    ~My Home/Limit switches arent' working. I'm using a C10 break out board and have them wired into ports 12,13,15 as the documentation calls for. How do I set this up in Mach 4?
    ~My E-Stop isn't working either. Again, wired according to the diagram, but doesn't trigger when it's pushed in.
    ~How do I reverse my X and Z motor direction? simply checking the "Reverse" check box in the motor tab for that specific motor doesn't do anything...
    ~last (for now), I'm not sure where to wire my Z touch off plate. It's a puck style with 2 wires, one has a alligator clip. It looks like Mach 4 has the function built in, but i'm not sure where to wire it.
    Thanks for all the help!
    -Bob
    Aug 2008
    213
    Bob,
    Did you ever get this straightened out? I am looking at upgrading my Taig CNC with the MACH4/Warp9 ESS/not sure on the BOB/driver yet.
    Please advise if you have figured this out.
    Thanks,
    Pete
    Jun 2017
    32
    Most likely swap wires A+ / A- to the stepper / servo.
    Ah - didn't notice question was 8 months old. Trust this was resolved by now.
  1. Mach3 to Smooth Stepper - Mach settings ??
    By JQ_Quint in forum Spindles / VFD
    Last Post: 02-01-2015, 12:17 PM
  2. Mach 3 interface to stepper motor driver
    By dhookings in forum Machines running Mach Software
    Last Post: 05-28-2014, 05:48 PM
  3. Smooth Stepper G540 and Mach
    By dfmiller in forum Gecko Drives
    Last Post: 06-13-2011, 05:32 PM
  4. how turn stepper motors off when not in use in Mach 3?
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 01-01-2009, 03:24 PM
