603,943 active members*
3,300 visitors online*
Results 1 to 6 of 6
    May 2006
    202
    Thumbs up Mach III error message-Help
    I recently purchased the new tri-Power CNC, which comes with the MACH III software. I'm using BobCad/CAM software to produce drawings and generate the G-code, no problem there. the Tri-power uses the parallel port on the computer to control the CNC processors on the machine and BobCad uses the RS-232. In order to get the machine running you have to save the bobCad file and then import it into the MACH III, no problem there. I generated a small program to do some milling and then loaded into Mach III and received the following message, "F word missing with inverse time arc move on line number #5". I contacted bobCad support and they had me send the program to them and they got it to run with no problems. I'm waiting for Camtronics in seattle to open so that I can call them, but though maybe someone could help in the mean time.
    Ben
    Jun 2003
    1365
    Can you post your code? Its likely the feedrate isnt right somewhere. and why are you running inverse time?
    Jon
    Mar 2003
    35494
    Are you using the Mach3 post from BobCAD's site?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2006
    202
    Error message
    That's what the bobCad generated gor the G-code. I'm new to machining so no familar with inverse. I can save the bobCad file to the Mach III and then load it into Mach III, then the error message shows up down at the bottom.
    Mar 2003
    35494
    Post the code here and we'll have a look.
    Gerry
    May 2006
    202
    thanks guys, but I called Camtronics and they had me do some config stuff and that fixed the problem.
    Ben
