603,946 active members*
2,438 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > mach2 i can jog at a max speed of 30 ipm but it wont feed that high?
    Dec 2004
    32
    i can jog at 30 imp
    if i right G1 x2. F25.
    it only runs at 15 ipm (not the 25 ipm i ask for)
    if i enter 10 ipm it will run at 10 ipm (like it should)
    is there a max feed seting a havent found one
    the rapid only run at 15 max also
    Mar 2003
    35494
    You probably have your motor tuning set too low. That is what sets your max speed.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Max IPM Possible with Motor
    By Sanghera in forum DIY CNC Router Table Machines
    Last Post: 04-08-2005, 07:05 AM
  2. Feed & Speed Help
    By kaleem1 in forum MetalWork Discussion
    Last Post: 11-04-2004, 02:21 PM
  3. Mach2 for high feed rates?
    By InsaneEPP in forum Mach Software (ArtSoft software)
    Last Post: 10-27-2004, 12:17 AM
  4. Spindle Speed & Feed Rates - Question
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 07-24-2004, 12:24 AM
  5. min speed exceeds max speed for axis "x"?
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-19-2004, 02:49 PM
