587,240 active members*
3,682 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach2 remembering position after shutdown..how does it know
Results 1 to 11 of 11
    Jun 2004
    258
    Hello guys.
    I have the machine working.. have yet to set up home switches.
    My question is:
    After I have finsihed for the day I set the machine about in the middle. The DRO's note the position. After switching everything off and then re-starting Mach2 doesn't rememebr its last position and I have to re-set the Zero positions.
    I know home switches tell Mach2 where home is, but...
    But if you switch a machine on and it doesn't know where it is...how would Mach2 even know which direction to start looking for a home switch.
    For example... if the machine was at the X+, Y+ extremes on startup and the DRO's all show Zero.... how does Mach2 know which direction to go?
    Is there so way of locking the DRO's/position on shutdown?
    cheers
    Frans
    Mar 2003
    6855
    You should be able to set the direction of travel towards the limit switches. So when you hit the home button mach know which way the axies must move to hit them.
    Mar 2003
    35538
    Look under Config>Homing, under the section "homing direction".
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2004
    118
    If you would like it to store your last position (On power down) you can check the copy G54 from G59.253mon start up under the config/state menu. as for homing it will go + or - dir and it matters not where it is on power down or up.
    Hope that helps
    Brian
    Sep 2003
    226
    I think this is what you want though Art warns that it does not guarantee exact positioning.
    Config>Logic configuration> Persistent DROs
    There is a check box for it.
    Explained in MACH 2's new manual, page 5-25
    Mar 2003
    35538
    Quote Originally Posted by sol
    Otherwise known as 5.8 in the index.
    Gerry
    Jun 2004
    258
    Thanks for your help. I'll give your suggestions a try.
    Many thanks...
    Feb 2004
    2337
    After every cut the gcode will return the machine to zero. If you turn on mach2 in the mornings it will assume the axis are at zero, and it will be. You just have to set the Z axis only.
    If however you bumped your machine while it was off your zeros would be out, and it could cause all sorts of dramas.That is why it is wise to either have zeroing switches or just set up all your machine each morning.
    Being outside the square !!!
    Jun 2004
    487
    I forget the exact term but Mach2 has something called "persistent DRO" that will store the last location before it quits. Next time you launch it, it loads these values to the DROs and you're set. Of course, keep in mind that there's a good chance the position will change when you remove power from your motors so keep that in mind.
    JR
    Nov 2003
    634
    FYI, All the professional CNC routers that I have used require a homing operation to zero out the axis before you can run the machine. Once a day, or once every time you turn the machine on.
    Too many things can happen when the machine is switched off to guarantee positioning accuracy.
    Mar 2003
    35538
    I can push my 1000 lb cantilevered gantry around when the machines turned off. And, if the router is at the far corner when I turn it off, the dust collector hose will actually pull it when the machine is switched off. So you never really know where it's at until you home it.
    Gerry
  1. CNC lathe tool and work offsets
    By mm4039 in forum MetalWork Discussion
    Last Post: 11-18-2013, 06:28 PM
  2. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
  3. Mach2 Faro Arm Inverse Kinematics
    By vacpress in forum Uncategorised CAM Discussion
    Last Post: 05-28-2004, 03:14 PM
  4. G Code and Mach2
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 03-13-2004, 08:46 PM
  5. mach2 versus EMC
    By georgebarr in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2004, 06:32 PM
