or you could make a differant zero plate that doesn't require a connection to the router bit. something with a spring switch in it for example Another solution is to purchase a differant router that's not doubly insulated like the Bosch. for example the PC690. Yes I use a Bosch right now, but that's being changed next week as soon as the Precisebits collet set get here.
