603,936 active members*
2,123 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Mach3 Breakout Board 5 Axes PWM to VFD output problem...
Results 1 to 7 of 7
    Oct 2017
    5
    I am using Mach3 Breakout Board 5 Axes on my second Parallel port for Spindle switching ON/OFF, Spindle speed controlling (PWM 1-10V output) and Auto Tool Zeroing...
    When I try to change spindle speed from MACH3 I get only 0 to 1.865V on output pins... Also there is about same value of 1.865V on LM317 output pins...
    LM317 input voltage is 14V
    LM317 output voltage is 1.865V
    Voltage between ADJ and Vout is 1.25V
    Resistance ADJ to GND 20KOhm
    Resistance Vout to ADJ 24KOhm
    Any idea, and/or schematics of BOB?
    Oct 2017
    5
    Re: Mach3 Breakout Board 5 Axes PWM to VFD output problem...
    PWM looks OK on oscilloscope....
    Oct 2017
    5
    Finally... Everything works now...
    There is production error on this board... Resistor R19 and Capacitor C4 are replaced during manufacturing of the PCB.
    Also, in my case, Resistor R5, R18 and R19 are wrongly calculated (in relation with LM317), so I add multi-turn potentiometer in parallel with R19 (between Output and Adjustment pin on LM317) and fine fix maximum voltage (10V) for 100% spindle turning (BOB output to VFD).
    Before>
    Sep 2005
    1198
    How did you check them wrong ?
    Oct 2017
    5
    Quote Originally Posted by asuratman View Post
    Did you mean that "Resistor R5, R18 and R19 is not calculated according LM371 datasheet"??... And because of that output voltage from LM317 was 1.865V and from bob output to VFD from 0 to 1.865V!
    According LM317 datasheet>
    Code:
    VOUT = 1.25 * ( 1 + R2/R1 )
    Nov 2017
    I'm new to the forum
    a question, what is the output voltage on the pull / dir pin, with 24v power on the 5 axes breakout board
    Mar 2007
    2083
    the pulse & direction pins switch between 0V & +5V depending on the output signals from your parallel printer port ( or motion controller)
    they are connected to the output pins of a 74HC245 octal buffer that is powered by the USB connector input
    the +12 to 24V power is only for the analogue PWM spindle control circuit and the input side of the 5 input opto-isolators for the E-Stop & limit switches
    a while ago I reverse engineered the TX14175
    Attachment 377410
    I would expect your Mach 3 interface board to be like this
    Attachment 377412
    basically the TX14175 with the LM2576 5V regulator and B050LS (DC to DC converter) replaced by the USB 5V supply
    John
  1. C10 breakout board with VFD using MACH3
    By albert_chuy in forum Automation Technology Products
    Last Post: 02-10-2016, 07:08 AM
  2. USB BREAKOUT BOARD FOR MACH3
    By JACKY2014 in forum USB, RS232, PARALLEL etc
    Last Post: 07-27-2015, 12:44 AM
  3. Mach3, Cnc Breakout Board, CM-126
    By Robiz in forum News Announcements
    Last Post: 11-12-2013, 01:22 PM
  4. CNC Breakout Board, CM-106, Mach3
    Last Post: 10-08-2013, 06:12 AM
  5. breakout board for mach3
    By albaboun in forum Machines running Mach Software
    Last Post: 04-23-2012, 01:43 PM
