588,199 active members*
5,026 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > MACH3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
Results 1 to 1 of 1
    Jun 2011
    75
    Multifunctional Board.
    ** MACH 3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable **
    ** Description **
    * For Mach3, EMC2
    * 4 axis 1 Pulse(DIR, PULSE)
    * Line Drive Output
    * 5 Sensor Input
    * 2 Relay Contact
    * Charge Pump function
    * +24V DC Power
    * 50mA Current Consumption
    * Spindle Speed Control - DC Voltage(0~10V)
    * Vertical Parallel Port Connector
    * Removable IN/OUT Connector
    You can get detailed information for free below pdf-file
    http://gahueyn.netii.net/CNC%20Board...100_Manual.pdf
    or Pls..Visit to ebay page.
    MACH 3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable | eBay
    Attached Thumbnails Attached Thumbnails Main_CM100 Picture_No Cable 3_1_1 copy.jpg
  1. Keling DB25 Breakout Board Problem
    By jimbar99 in forum Automation Technology Products
    Last Post: 09-16-2013, 10:38 PM
  2. CNC Breakout Board / Mach3 / EMC2 / DB25 (CM101)
    By Robiz in forum News Announcements
    Last Post: 07-08-2011, 04:29 PM
  3. MACH3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
    Last Post: 06-28-2011, 03:34 PM
  4. CNC Breakout Board for Mach3/EMC2/DB25/Parallel Cable
    Last Post: 06-17-2011, 07:28 AM
  5. Pin 1 KL-DB25 Breakout Board?
    By gremilRoute in forum Automation Technology Products
    Last Post: 06-18-2009, 10:38 AM
