Hello,
we have two machines to drill counterbores in sheet metal. One of them has Mach3 as CNC controller.
Due to warping of the sheetmetal wie have a drillhead with down hold funktion via gas springs.
On the other machine we have a sensor on the drill head and a digital input to end a custom G81 cycle bevor it reaches the programmed depth if the counterbore is deep enough.
The Z-Axis stops and returs to the SafeZ Position. Controller on this machine is Tekna OEM software.The concept works really fine (tollerances +-0,1mm), that is why I want to stay with this solution.
Now i need a methode to do this on the Mach3 software.
Can you give me some advice how to archive this?
It doesn't have to be a solution with G81, i want to use a macro with the parameters for the holes.
Info:
Mach3 R3.043.066
IO: CSMIO_IP
Best regards
