Hi All
I have just set up a machine and I have done some test cuts, if I do a test with a square pocket the machines cuts fine but anything at all with any kind of radius or circle in it the feeds just drop down to an absolute crawl and I can work out why.
the maximum velocity in my machine is set to 750 and if specify a square pocket with a feed rate of 750 the machine will cut it fine and mach3 behaves as it should, if do say a circle and specify any feed rate at all it disreagards it and cuts at a feed rate of about 5% so a 6mm hole in a piece of mdf takes about 10 minutes to cut
I really hope someone can point me in the right direction as I am pulling my hair out here
Cheers
