603,963 active members*
3,182 visitors online*
    May 2018
    30
    mach3 interface
    Hi, I hope you can help me. I'm trying to install the limit switches in a mach3 interface in the cnc, but I can't find the solution, the green cable can't find it.
    Jan 2018
    1516
    Re: mach3 interface
    Quote Originally Posted by tazma View Post
    Hi there.
    For a start. Those boards need a 12-24 power supply attached to the middle 2 pins that say 12v-24v/gnd on the right hand side for the inputs to work. If you don't have that then the inputs have no power.
    https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
    I have no idea about the green wire but my NPN 3 pin/wire inductive switches have brn/blue/blk. Those wire in as: brn= v+, blue= gnd, blk= xyz trigger.
    I assume either the blk or grn on yours are v/gnd or signal. (this is all assuming the red is v+).
    You need to figure out which is the gnd wire (either grn/blk will be) then the other will be the trigger.
    This is a basic image of 24v inductive switch wiring both npn or pnp:
  1. cnc + laser +interface mach3
    By tazma in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2020, 07:44 PM
  2. Robotic Arm and Mach3 interface
    By Bow Hunter in forum Machines running Mach Software
    Last Post: 10-10-2012, 07:02 PM
  3. Mach3 settings for Interface board
    By mandiares in forum Stepper Motors / Drives
    Last Post: 04-30-2012, 01:56 AM
  4. Encoder interface for Mach3
    By ishman in forum Mach Software (ArtSoft software)
    Last Post: 04-18-2012, 05:19 PM
  5. Will MACH3 interface to Heindenhain drives
    By jbcj in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2009, 03:04 PM
