603,982 active members*
2,664 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mach3, Mach 4 or Linux CNC for G0704
Page 7 of 8 5678
Results 121 to 140 of 152
  1. #121
    Jun 2014
    777
    Re: Mach3, Mach 4 or Linux CNC for G0704
    I dont think accuracy is so much the issue in this case, its just runs lumpy. Definitely was in cv mode. Could well be that mach 3 has some retarded code that disables CV mode selection as default, this sort of stuff really angers me, yet another reason to avoid mach 3 for general mess around. Like i say the motor tuning was the same and machine is tight enough to handle the speed as you can see the proof is in the pudding with the uccnc example. . Could it simply be the lack of decent motion control in the basic mach 3 bob that comes with the Chinese 6040. Who knows, a fairer test would have been trying 3 versions one using the uc400 mach3 plugin. frankly i dont intend on looking into it as the problem has been solved by uc400 + uccnc.
  2. #122
    Jun 2007
    3891
    ah ok. then ill bet cv is disabled.
    ill go dig up the setting tonight for you and then you could retest (air cutting will tell you instantly just be sound).
  3. #123
    Mar 2003
    35494
    In Mach3, make sure that when using CV mode, that ALL CV options are turned off, except for Stop CV on Angles. Both CV Feedrate and CV Distance should be off, and all the other settings in General Config.
    And make sure your lookahead is not set to a very low number.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  4. #124
    Jun 2014
    777
    I will fire it back up and double check, for the purposes of the test i simply matched the mach 3 cv settings to the default uccnc settings. cv distance & cv feedrate setting is not used in uccnc so no value would have been entered and i cant be sure whether that was on or off.
    Look ahead was set at 300 lines, angle 89.
    But to me as feedrate was maintained and cutting time matched that of uccnc, even with the cv settings (which must be off?? why is this?) id expect result to be better than they were. Just seemed like a massive lack of smoothing which does suggest ihavenofish was correct in that is was in exact stop mode and down to the complete idiocy of mach 3 in which case it Needs a warning " these settings may not actually change anything"
  5. #125
    Jun 2007
    3891
    cv feedrate, thats the one! thanks ger.
    i never turned off cv distance though (or maybe it was already off, cant remember).
  6. #126
    Jun 2007
    3891
    Quote Originally Posted by Jon.N.CNC View Post
    if cv feedrate is set to 1 in the xml, g64/cv is effectively off.
    sometimes mach3 can go really fast with cv off, but the thing will vibrate like mad which is the giveaway that its not working right.
  7. #127
    Jun 2014
    777
    Was correct in terms of feed rate. Sounded okay, not as smooth as ucnc but no visible or audible vibration and cutting foam is very quiet.
  8. #128
    Mar 2003
    35494
    I would say that you definitely have some type of issue to get cuts like that with Mach3, CV mode or not.
    Gerry
  9. #129
    Jun 2014
    777
    I'm convinced it's no or poor motion control, as with many cheap Mach 3 bobs
  10. #130
    Jun 2007
    3891
    the break out board has nothing whatsoever to do with motion control. it only relays pulses from the parallel port with little or no alteration. all motion control is handle within mach3 on the pc.
    a break out is going to either work or not work. there wont be any in between - certainly none that could cause what youre seeing there.
  11. #131
    Jun 2007
    3891
    another note, some drives are sensitive to pulse timing, and will lose widely spaced pulses from mach3. geckos are notorious for this.
    whats basically happening is the drive looses steps and appears to "flatten" direction changes, like on a circle for example. it almost appears like backlash. most programs have many reversals and end up often in the same place, and can appear not to have lost position despite be waaaay out.
    if you check "sherline mode" in the main setup page (where you set core frequency) this will switch mach3 to a 50% duty cycle on the pulse stream and will fix this issue.
  12. #132
    Jun 2015
    943
    I think Jon thought about a motion controller BOB which is a motion controller + BOB all in one which chinese often manufactures and sells on ebay and other places like that.
  13. #133
    Jun 2007
    3891
    Quote Originally Posted by OlfCNC View Post
    id hesitate to call those motion controllers. they are pulse generators. mach3 is still controling all motion. i can see a pulse generator card with bad synchronisation between axes making some crap cuts. ive avoided those usb cards (including smooth stepper), they tend to be plagued with issues.
  14. #134
    Jun 2015
    943
    Yep, but 99.99% of the people call them motion controllers and they are sold on that name, so it is the term what it is called by people and on what name people know these devices.
    Anyways I just wanted you guys know what Jon might thought about when he mentioned "BOB" on that 6040 machine.
  15. #135
    Jun 2015
    943
    I'm curious what would you use then?
    The only other option I know about is the LPT port. But in my understanding then the "pulse card" is a PC software module which is very likely to be worse than a microcontroller timed external pulse card.
  16. #136
    Jun 2007
    3891
    parport i use with mach3. works just fine. only drawback is limited speed and limited number of io. a microcontroller like the avr/arduino cant compete here, nowhere near enough speed to be useful for a fast router, it can indeed control steppers n such... but it so out of its depth on a 3 or 4 axis high speed router or mill.
    on linuxcnc i have a mesa card - which is a high performance pulse generator.
  17. #137
    Jun 2015
    943
    I see, ok. But LPT port is acient-ware and the thing Windows is not realtime caused me lots of troubles like instantly stopped motion when Windows updates and other softwares kicked in and things like that and jerky unprecise timing pulses.
    With the UC100 motion controller or "pulse card" my steppers can run about 160% faster probably just because the timing is better.
    And I don't think you are correct about the micro or FPGA can't do the same speed, I mean the same amount of information could be throughput on a USB or ethernet connection faster than on an old obsolete LPT port and then that information only needed to be reconstructed back to pulses on a parallel port looking connector or something like that.
  18. #138
    Jun 2007
    3891
    hahahah.. no. just, no. you set up the machine to work as a cnc control, not a web surfing box. you turn everything off. ive never seen any for of "windows" issue running mach3.
    timing might be better, hard to say. mach does not have the best timing (hence the misses slow pulses i mentioned), but i dont think thats parport related, or mach related. linuxcnc has much better pulse timing than mach3, and its also just software.
    you said grbl. that implies arduino level stuff. theres plenty of higher power systems out there for sure, but they dont cost $9.99 on ebay also theres a reason ethernet and usb are not used much and parport is. parport works. sure its slow and limited, but it works. ethernet and especially usb are inherently not realtime. so called realtime ethernet system like my beckhohf ethercat system are not really ethernet as you know it. they use the host tranciever and cable, but its all proprietary protocols. you cant stick your modem or printer on it
  19. #139
    Jun 2010
    4260
    That foam still puzzles me a bit. Too many of us have machined too many curved things with Mach3 and had really excellent results to just say it's a defect in Mach3. It just does not compute that way.
    On the other hand, foam can be really tricky stuff to machine. You really need to 'keep moving and not stop' if you don't want gouges in the edges. When the cutter stops moving the foam sometimes seems to pull in around the cutter. Very bumpy edges - which is what this looks like.
    Cheers
    Roger
  20. #140
    Jun 2015
    943
    Haha, I'm watching vids (Youtube all day long with running the UC100/400 "pulse cards" and never had any problems.
    Yep, I have one VMC also, that uses EtherCAT, but that is just not the same price range, I mean it is no $9.99.
    And this is why Mach3 "pulse cards" come with plugins running motion buffers, to overcome the non-realtime issues.
    In summary I do not think the problem is with the concept of using a USB or ethernet card, I think an issue can be if one is not properly coded or made.
Page 7 of 8 5678
  1. Replies: 2
    Last Post: 05-29-2013, 07:36 PM
  2. Mach 3 vs Linux Cnc
    By tamartin in forum Benchtop Machines
    Last Post: 01-29-2013, 02:23 AM
  3. Linux/EMC VS Mach3 Where to Start
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 01-29-2008, 03:46 PM
  4. Anyone try mach3 with linux/wine
    By timmyb199 in forum Machines running Mach Software
    Last Post: 10-23-2006, 07:32 AM
