I am using sige x2 converted mill with mach 3
I have tried to engrave letters and logo on dual colored plastic.
And I have noticed that the machine doesn’t finish the cut as it suppos to do.
As you can see form the screen picture , the letters have 90 degrees angels on the corners but the cnc is cutting it with a "short cut " to the next points.
The same is happening on the Z axis and it doesn’t finish the letters (or the logo).
I have tried to generate the code with the Lazycam and solidcam and the results are the same.
Any suggestion?
ThanksAmnon
