603,907 active members*
4,403 visitors online*
Results 1 to 7 of 7
    Jan 2005
    253
    Mach3 Mill Pausing Problem
    Starting tonight, my machine seems to be pausing after each revolution of a helical cut.
    G0 X0.4680 Y0.8020 Z0.2500
    G1 X0.4680 Y0.8020 Z0.0000 F10
    G2 X0.4680 Y0.8020 Z-0.0671 I0.0000 J-0.0200 F25
    G2 X0.4680 Y0.8020 Z-0.1343 I0.0000 J-0.0200
    G2 X0.4680 Y0.8020 Z-0.2014 I0.0000 J-0.0200
    G2 X0.4680 Y0.8020 Z-0.2686 I0.0000 J-0.0200
    G2 X0.4680 Y0.8020 Z-0.3357 I0.0000 J-0.0200
    G2 X0.4680 Y0.8020 Z-0.4029 I0.0000 J-0.0200
    G2 X0.4680 Y0.8020 Z-0.4700 I0.0000 J-0.0200
    It will do one loop, pause for an instant, another, pause...
    Anyone have any ideas?
    Andy
    CNC Kits - http://www.comptonsoft.com/cncweb/
    Mar 2003
    35494
    Did it work OK before with similar (or the same) code? Try it using the half circle code (Output 180°). Does it do the same thing? I only run Mach3 in simulation mode, and have never seen a pause.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2004
    145
    Are you running exact stop or constant velocity? Exact stop will do this.
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Mar 2003
    35494
    I didn't even think of that. I bet that's it too.
    Gerry
    Jan 2005
    253
    Ah, good info. I might have accidentally changed a setting. I'll see if I can figure out how to change it back.
    Andy
    Mar 2003
    35494
    It's under Config>State I think, or put a G64 at the start of the code.
    Gerry
    Jan 2005
    253
    Yay! That was it. Thanks guys.
    I don't know how I did that. Must be a button on the interface somewhere I hit.
    Andy
