I require help on automation of a punch press. I have added a X Y table to the press and propose to add two stepper motors from Automation Direct to the two axis of the table.
The operation will be as follows:
On each stroke of the power press (operating at 45 strokes per minute) the X-axis indexes the material for the next hole in the row.
After completing 5 strokes, the Y-axis indexes the material for the next row.
The operation continues for 15 rows and then Y-axis brings the table to the starting position and the operation stops.
The stepper system is for the purpose of convenience of changing the number of holes in a row, the number of rows, the distance between the holes and the distance between the rows for a variety of jobs.
Is it possible to control the above operation through a PLC only?
Or
Do I need some software on computer to control the operation?
If both systems are possible, which one is cost effective and simple to operate?
Thanks,
R. Rossey
