603,936 active members*
2,318 visitors online*
    Aug 2011
    Machine can not maintain the Plasma! Help
    We problem, when we start cutting, the cut Head will go down , touch to material and go up, then plasma will spray for cutting. But Plasma spray a little, machine can not maintain the plasma spray, then Cut head go up and STOP.
    After that, we turn off the machine many times and it can work, but for 15 mins, the problem happens again!
    We checked all the cable which is fixed in machine, ground.
    We use 100Amp, machine work normally, problem just happen with 200Amp.
    Who know about this issue, please help me. Thank you so much!
    Kakashi!
    Jan 2008
    2247
    Need more information to help.
    - What type of cnc machine, control and torch height control?
    - What brand and power level (model) plasma?
    - What materials thickness and type?
    - Your consumables (amperage rating) and cutting power level when problem occurs?
    - Your settings: Pierce height, pierce delay, cut height?
    Jim Colt Hypertherm
    Aug 2011
    Thank Jimcolt for support me!
    This is DAMA DMP 2060 machine, Burny 10 controller, the plasma is Hypertherm Max200.
    We cut mild steel with 16mm thickness, we used 200 Amp ARC Current setting, and ARC Voltage setting is 135V,
    Torch to work is 3 mm, Pierce height is 6mm.
    Kakashi.
  1. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  2. How to maintain spherical
    By steven alex in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2011, 04:32 PM
  3. Looking to mentor on Okuma Macturn (program, operate & maintain)
    By calgarykevvy in forum Mentors & Apprentice Locator
    Last Post: 07-04-2009, 05:11 PM
  4. Maintain windows display order?
    By ckirchen in forum PTC Pro/Manufacture
    Last Post: 12-04-2008, 06:27 PM
  5. Flood Coolant - how to maintain?
    By Rich05 in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2008, 01:06 AM
