587,999 active members*
2,225 visitors online*
    Oct 2007
    Machine Choice Advise
    Hi to all:
    I am new to this forum. I have a home-built cnc router but need to add an additional machine to cnc cut aluminum & steel. I do not have the time to find an older manual mill & convert to cnc. I have been looking at the Tormach & the Industrial Hobbies machines. I would appreciate any suggestions or comments about these two machines or any others I may have over-looked. Looking for something larger than a desktop but smaller that a full-sized floor mill.
    I would prefer a machine to run using Mach3. I mostly use V-Carve Pro and some Artcam stuff.
    Thanks to all in advance.
    Rusty
    Nov 2007
    7
    i am new here
    i am also new here, i am in the line of laser engraving and cutting machine, if any body need help can contact [email protected].
  1. VF2-SS is that a bad choice of machine??
    By bob1112 in forum Haas Mills
    Last Post: 06-28-2010, 11:42 AM
  2. Help in the choice!
    By nalmeida in forum DIY CNC Router Table Machines
    Last Post: 01-14-2008, 08:05 PM
  3. newbie needing help/machine choice
    By ricko27 in forum CNC Tooling
    Last Post: 05-30-2007, 02:08 AM
  4. If you had the choice, which SS would you choose?
    By PEU in forum MetalWork Discussion
    Last Post: 10-06-2006, 01:19 PM
  5. VFD choice
    By zcases in forum Phase Converters
    Last Post: 09-30-2005, 02:59 PM
