587,374 active members*
3,583 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Machine drills square holes in metal.
Results 1 to 7 of 7
    Jan 2008
    241
    Is this thing for real?!
    Too Cool! :cheers:
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Dec 2006
    839
    Ofcourse its for real, its something close to a rotory broach but a differenet way of doing it.
    In the slow motion vids you can see the action it uses to accomplish the task. Pretty cool really and I am not 100% sure how they get it to do like that but its clear to see its doing it.
    Whats odd it appears its more than just a new tool, like somehow part of the action is built into the spindle thats running it. I guess we will see more of it in time if it proves to hold up & be cost effective.
    Jess
    GOD Bless, and prayers for all.
    Jun 2010
    4259
    Maybe
    Quote Originally Posted by Mogal View Post
    Technically possible. Note complex gearbox up top. Suitable for aluminium etc, but I would want to rely on it lasting a long time on hard steel. High wear rate.
    Cheers
    Jul 2005
    12177
    The operating principle has been known for years and I guess I saw my first example at least thirty years ago. The hole is not perfectly square there are small radii in the corners.
    May 2004
    200
    that reminds me of how a rotatory engines rotor wobbles as it's running
    Aug 2011
    This type of thing has been around for quit a while. If i remember correctly it involves two slotted plates mounted horizontally together on a spindle or arbor in a manner that allows the two plates to move in a manner allowing the the cutting tool to move in the way as seen in the video. Each plate has two slots that are parallel and set towards the outer edge and the plates are mounted at 90 degrees to one another. This type of thing was normally mounted in a drill press and was quite common in work shops.
    Jun 2010
    4259
    Huh - even I can do that!
    Drilling non-round holes is easy!
    I can drill triangular holes with an ordinary twist drill ...
    Cheers
    PS: it's actually just about the same technique too !
  1. square holes
    By JPMach in forum MetalWork Discussion
    Last Post: 11-12-2011, 05:29 PM
  2. square pockets and holes?
    By sabastion in forum Benchtop Machines
    Last Post: 08-09-2011, 04:08 PM
  3. Replies: 5
    Last Post: 08-31-2010, 04:48 PM
  4. Drilling square holes ??
    By FPV_GTp in forum MetalWork Discussion
    Last Post: 08-28-2009, 08:38 AM
  5. square holes - reciprocating file??
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-21-2005, 02:44 PM
