What I thought was a "brilliant" design of mine has disappointed me! I've made an aluminum extrusion frame router/mill with Hiwin 20mm rails and 1605 ballscrews. My goal was to be able to machine aluminum. It can but it's really wimpy. I have to take really small depths of cut. If I try to use the side of the end mill to machine the edge of a 1/2" thick plate, I get this terrible high-pitched squealing resonance that develops; when I take a cut of more than 0.5 mm into the part.
Here's a video showing the machine moving in all axes: https://www.youtube.com/watch?v=nWbaQHA50cI
Can anyone see an obvious weak point that causes low stiffness? My estimates suggested this would be quite a capable machine. There are several resonant modes right in the wrong spots down at low frequencies.
Here are some pics:
This is the front of the machine. It has dual y-axis ballscrews, a single x-axis ballscrew, and the entire gantry moves up and down for the z-axis, so the Z has two ballscrews
Here is a side view of the machine, showing the gantry plate, and one of the y-axis ballscrews
Here's a view isometric showing the rear. One can start to see the dual z-axis ballscrews
Here's a straight-on view of the rear of the machine
A closeup of the x-axis, showing the headstock and its drive motor. That's a hobby brushless motor. I use a regualr helicopter ESC to drive it and an 18 V power supply. The pulleys from motor to spindle have a 1:2 ratio.
Here's a closeup of one of the z-axis ballscrews attachment points to the gantry.
