603,855 active members*
3,876 visitors online*
Thread: machine home
Results 1 to 7 of 7
    Apr 2009
    31
    machine home
    hi all
    i have a problem in machine home point ,
    when i press home push button while machine is stop in any point , machime didn't go to home point correctly in X axis and Y axis... just move short distance in this axis and stop and machine coordinate became X0 Y0 Z0 .
    but this place not the spicific place for home point .
    you know the most of CNC machine , home point in the left bottom machine work ... now machine define the point it already stop in there as machine home point .
    this happend when i press home push button in this position .
    pls. advise
    Apr 2009
    4
    Your ruler or lineaal, it's an magnetic strip by which the machine defines where it's actual position is,(x,y,z axis) maybe a little dirty.
    The machine, sometimes, can give some strange side effects like running over referencepoint or will give a referencepoint reached while it has not.
    Just clean it up & it will work again like before.
    If your machine has heidenhain onboard you can try this (keep the feedrate to < 5&#37;, crashes are possible on a dirty ruler) ;
    M30
    X0 Y0 Z0 m92
    M30
    Apr 2009
    31
    hi
    r u meaning sensor ?
    what do you mean of ( lineaal ) ?
    Apr 2009
    4
    Lineaal is the part called in Dutch, i don't know the English word for it,
    I translated it with an online dictionary where it was translated to ruler in English if this was an correct translation i don't know.
    It could also be the sensor attachted to this ruler.
    Dec 2008
    3216
    I think he is refering to the linear "scales" on each axis
    Apr 2009
    31
    no no no
    sorry but thats not the problem.... i forget to tell you machine is working good ... but just no move in X axis when i press home boutton ... but X axis moving in jog mode and automatic mode good .
    i think may be it hardware problem ... what's your opinion ?
    Mar 2003
    2932
    What machine? What control?
  1. Home Built Edm Machine
    By sanjiv in forum Waterjet General Topics
    Last Post: 04-13-2018, 03:25 AM
  2. Home Made Injection Machine
    By Rob_M. in forum Moldmaking
    Last Post: 11-12-2012, 02:47 AM
  3. machine home problem
    By traxxtito in forum DNC Problems and Solutions
    Last Post: 04-27-2009, 09:15 PM
  4. If you have a 300 or more pound machine can you tell me how you brought it home?
    By slashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2009, 12:02 PM
  5. Please Recommend a Home welding machine
    By ThomasAlva in forum Welding Brazing Soldering Sealing
    Last Post: 08-23-2007, 07:34 AM
