603,940 active members*
2,350 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > machine is limiting after tool changes.
Results 1 to 4 of 4
    Dec 2007
    73
    Machine is moving to machine limit after tool changes. Is there a setting in BC I may be missing and need to change? I am using a Taig mill and Mach 3.
    Thanks for any help.
    Mike
    Feb 2009
    68
    I'd change your tool change position in tour program manually.
    Aug 2009
    684
    Your M6 Tool Change Macro may finish in G91 incremental mode. You may need to put a G90 in your program before next movement.
    Also you may need a Z-move with your G43.
    DP
    Apr 2008
    1577
    If you copy and paste a bit of the BobCAD posted code someone might be able to know for sure. DP sounds like he might have some insight. Either way, your Post Processor likely needs modified. If you aren't comfortable doing this yourself, you can post it here to the forum.
    FYI .MillPst files can't be uploaded directly to the forum. You will need to ZIP it first.
  1. Limiting resistor formula help
    By jchuchla in forum Stepper Motors / Drives
    Last Post: 02-24-2009, 12:36 AM
  2. Optical limiting switches
    By oxford in forum Benchtop Machines
    Last Post: 07-25-2008, 11:37 PM
  3. Choppers VS Limiting Resistors
    By camcam in forum Open Source CNC Machine Designs
    Last Post: 04-20-2008, 06:00 AM
  4. Current Limiting For Steppers
    By waleed alhadidi in forum CNC Machine Related Electronics
    Last Post: 11-11-2007, 01:44 PM
  5. current limiting R2 & R4?
    By obscurity in forum CNC Machine Related Electronics
    Last Post: 07-18-2006, 04:25 AM
