I have a Kitamura Mycenter 1 with OMC controls. This past Friday I got an alarm on the machine side, alarm 13 Spindle Oil / Air Alarm. Before reloading the parameters a year ago the machine will go into single block mode but I could move any axis around. This time I can't move a single axis and the single block LED will not light up. What parameter do I need to change? I think a waylube line was broken under the table and can’t move the table to fix it. Also where is the waylube pressure switch located? I can bypass the switch to get the machine moving around again so I can find and fix the problem.
Thanks!
