603,979 active members*
1,365 visitors online*
Results 1 to 11 of 11
    Jul 2014
    6
    machine makes the model incorrectly
    Hello,
    I bought the machine in China. He remote control DSP nk105. Machine size 0609.
    During the manufacture of parts of the machine errors occur.
    Here's an example:
    Attachment 243054
    when the machine completes the processing program, he did not exactly comes back to the point X = 0 Y = 0 Z = 0. Although remote writes that all point to the zero axis. Here's an example:
    Please help how to fix it?
    Dec 2007
    2133
    Re: machine makes the model incorrectly
    Do you have your acceleration set too high so it misses steps?
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Jul 2014
    6
    I tried at a low speed, the result is the same
    Jul 2014
    6
    I think that the problem is, the pulse equivalent, how it correctly calculate?
    I micro step 1:16 pulse equivalent 0.00625 mm / p, is that correct?
    Dec 2007
    2133
    It's not clear to me from your attachments if you are you accurately machining shapes, but the issue is the cutter doesn't return to the correct position, or if your machine also machining the shapes wrong?
    If the mm/p setting is wrong, I'd think you'd be machining shapes that should be repeatable, but shorter or longer in at least one of the planes. For example, if the mm/p was wrong for the x axis, the cut along that plane would generally be half, or twice as long as it should be depending on the setting used. From memory my Y axis 25mm ballscrew setting is set to 0.00625/p, and my X and Z 15mm or so ballscrews are set to 0.003125/p on my machine.
    If you machine a 500mm x 500mm square, what do you get as a result? A rectangle instead?
    cheers, Ian
    Jul 2014
    6
    result of the processing of the square is a parallelogram
    I have all the axes 15mm diameter shafts. pulse equivalent to 0.00625
    Jul 2014
    6
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    micro step you 1:8, am I right?
    Dec 2007
    2133
    Yes, 1.8 degree x 200 steps for a single revolution.
    cheers, Ian
    Jul 2014
    6
    Can you to photograph your drivers? How they are configured
    Dec 2007
    2133
    Sure, I'll be home in a couple of hours and email them through then.
    cheers, Ian
    Dec 2007
    2133
    Emails sent, hopefully they help!
    cheers, Ian
  1. Replies: 7
    Last Post: 08-04-2014, 11:21 PM
  2. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum News Announcements
    Last Post: 04-18-2014, 02:17 AM
  3. Replies: 4
    Last Post: 10-16-2013, 08:18 AM
  4. my engraving machine makes my circuit breaker stops
    By ouhla! in forum Engraving Machines
    Last Post: 10-27-2009, 04:30 PM
  5. crashed the machine, now spindle makes weird noise!!!!
    By lm6769 in forum CNC Machining Centers
    Last Post: 09-01-2008, 06:23 PM
