603,774 active members*
3,674 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > machine tool emergency stop DMU 50 V millplus heidenhain
Results 1 to 5 of 5
    Jun 2007
    4
    Have a problem with a DMU 50 V that sets the error code I05 when I press the start button. What can trigger that error code apart from the emergency stop switch , switch to the door and the switch for the windows slide in the tool magazine.
    Things that have been replaced in the security chain, door switch / lock (16A4) and the emergency stop button (S1) and start button (6SH1).
    All protective plates and doors are removed from the machine because the machine was higher than the door into the workshop, and to access and service the machine and clean it.
    Keys are in the switches for the tool magazine and the main door.
    Any suggestions on solving the problem are greatly appreciated.
    /Tobias
    Jun 2007
    4
    Re: machine tool emergency stop DMU 50 V millplus heidenhain
    Update
    The machine also set an error code on start up indicating that the hand control is not responding. Turned out to be a bad connection at the hand control end. When that error was fixed the error code I05 also disappeared. Either it's a bug in the control program or it is a deliberate programming in order to make troubleshooting a little bit more challenging :devious:
    Now remains to find out why the power supply to the servo drives does not start
    Apr 2017
    7
    Hi !
    I have same machine Dmu 50V Millplus v400
    i had to make emergency stop when i was driving reference points ( to invoid collision).
    I even move axes after i release the emergency stop button and restart. Then i start driving reference points again it made Stop in Y axis ( Y04).
    NOW the Problem If i try to start it again. The 01 wont shut down and non axes wont get power. Also the cabin door wont get close.
    Also in electrical cabinet power supplay 6 leds are off / no lights.
    IF anyone have solution i would be more than pleased to know.
    Hope Tobbe will answer had so similar case. THANKS
    - - - Updated - - -
    Hi !
    Sep 2019
    11
    Quote Originally Posted by Tampio66 View Post
    Hi !
    - - - Updated - - -
    Hi !
    Moi.
    Ittellä on nyt sama ongelma samassa koneessa. Muistakko miten ongelma ratkes? Pystykkö ottaan yhteyttä [email protected]
    Feb 2020
    18
    I have worked in this same machine.
    Contact me if your problem is not solved
    [email protected]
  1. Nomura NN25R CNC SWISS SCREW MACHINE - Emergency Stop --Need help
    By kirbhas72 in forum CNC Swiss Screw Machines
    Last Post: 09-04-2015, 12:01 PM
  2. Replies: 1
    Last Post: 09-02-2015, 09:51 PM
