Hello,
I am making CNC from old Copying machine. I used Solidworks to make most off machine drawings. These is no bottom part at drawing, and 5th rotation axisI attach photos. Need Help with everything, steppers, control system, constructing all axis. If someone could help it would be great. The constructions is totally balanced, good working machine. 3 axis is clockwise and 3 are counterclockwise.
I can spend up to 6k Euros. For starting I don't want to change motors that exist, maybe later.
My thoughts are to attach motors each side. For Rotation 5th axis install 1 motor, every wood part is rotating same time, by hand nowFor axis that controls turning to sides (left right) one motor, but don't know where and how to install it. For the axis with motors- 1 motor each side on axis, changing existing parts with new ones adjusted for motors install. Other axis is more problematic.
All thoughts are welcome!
Regards Dalius,
