I am machining a 15 x 15 x 2-1/2 forged block of 2219-t4 aluminum on a makino horizontal machining center.The part has rough finished dimensions of 14.500 OD and a 12.200 ID . No tube stock available. I made a part with the same dimensions out of 6061-t6 material and had no problems with warping after releasing the part.Now I am machining the forging and after releasing the clamps, the part is springing big time. Would stressrelieving before machining solve my problem, or do I have to change my process and rough machine, then reclamp and finish machine(which I would rather not do because it would mean more fixtures and more operations).Any sugestions would be welcomed. Thanks, Scott
