603,310 active members*
2,389 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Machining camshaft profile with radial tool in rotary mode
    Aug 2023
    Hi.. we work in new edgecam 2023.1. I’m trying to machine cams on camshaft with ballnose cutter in radial orientation using only c z and x axis on turning machine. I have activated rotary mode but it doesn’t seems copy the cams profile. It try to machine it in 90deg angle inside the cams. Is there anything i need to activate or change?
    Jun 2015
    4189
    Re: Machining camshaft profile with radial tool in rotary mode
    Hy, if you wont succed, i can help you with toolpath. Just provide cam profile dxf / kindly
  1. 2D Adaptive profile radial load?
    By rlaury in forum Autodesk CAM
    Last Post: 05-17-2022, 03:23 PM
  2. polar interpolation radial tool
    By zaheerabbas97 in forum G-Code Programing
    Last Post: 11-14-2014, 11:16 AM
  3. NEW : Radial Bi Rotary Engine
    By frankydevaere in forum I.C. Engines
    Last Post: 03-11-2011, 07:41 AM
  4. take apart a parlec radial tool holder
    By metlshpr in forum CNC Tooling
    Last Post: 04-08-2010, 12:40 PM
