603,942 active members*
2,683 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Machining Engine Rods
Results 1 to 1 of 1
    Oct 2006
    158
    I have a question about machining engine rods.
    Will be machining them out of 4340.
    The process will be:
    Machine all outside dimensions to spec.
    Leave the pin bores 1 to 2 thou undersize.
    Heat treat.
    Finish hone the pin bores .
    My question is. How do you keep the rod from twisting when they are heat treated?
    Aug 2008
    408
    Re: Machining Engine Rods
    How hard you plan on making them ? And why harden them ? Use pre-hard 4140 and machine it to size .
