603,390 active members*
2,909 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Aug 2008
    303
    Re: Machining kwik-switch 200 holders
    I chucked an original holder and indicated it so it would run true, then put the indicator in the compound rest and adjusted it to read zero along the surface of the taper. It's really not rocket science, and it worked well enough for me. In a perfect world, the taper should have been ground, but I don't have that kind of equipment here at home.
    The one that dies with the most tools, WINS !!
    www.dantechfabricating.com
  2. #22
    Dec 2006
    I tried to make an Qwik Switch 200 tool holder tonight. I'm going to make some of these with proper materials. Got the taper to a nice fit with your instructions. The taper on the Qwik Switch is exactly 1:6
    This was only a test to see if i would manage to make one. The tabs on the tool holder is to short, didn't want to waste any other material. This tool holder will be fine for the dial indicator.
  3. #23
    Oct 2008
    2205
    Well, Danno. You sucked me in. I'm going to have a shot at making some tool holders myself. Probably going to use some 4140 QT and press fit collar with ears. (Heat the collar, press it on.) I've actually got plenty of holders, but it would be handy if some of them had a longer nose. I'm going to have a shot at making long nose holders in all the sizes from 3/8 down to 1/8.
    Bob La Londe
    http://www.YumaBassMan.com
Page 2 of 2 12
  1. Kwik 200 Tool Holders - Several Sizes
    By Bob La Londe in forum For Sale Only
    Last Post: 05-11-2014, 12:53 AM
  2. Having problems with inserting tools holders in Kwik Switch master holder
    By want-to-be-cnc in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2013, 12:51 AM
  3. Kwik Switch 200 spindle
    By reabdet21 in forum Bridgeport / Hardinge Mills
    Last Post: 10-21-2012, 10:57 PM
  4. WTB Kwik Switch 200 Series Tool Holders
    By Shanghyd in forum Want To Buy...Need help!
    Last Post: 11-25-2009, 03:06 AM
  5. Kwik Change 300 tool holders
    By johnd in forum MetalWork Discussion
    Last Post: 02-27-2006, 09:27 PM
