hello, everybody I have to machine brass 360 , having some knurling to do on the O D at 2.25 and 96 diametral pitch (diamond) also i never did I D left hand thread so my question is whats the depth of cut for this particular material to turn, an how to go about the left hand thread ,should i just start the spindle in reverse and start from the inside, or do I need a left hand threading boring/b , and about the knurling how deep should i go into the material and at what speed on x axis, someone recomend to feed from .006 to .008 inches per revolution on the z axis at 125 rpm using wd 40 as a lubricant, thank you for all your help guys, any thoughts will be greatly appreciated thanks a lot.
