Im trying to machine a stepped pin. Like in the picture. I have both mill and lathe . I was thinking I could achieve this by offsetting the pin in a set of 4 jaw chuck on my lathe.
Any opinions ?
Any opinions ?
Yep, that method would work.
Do a search on the manufacturing methods for model engine crankshafts - there are several popular methods, and your part is much the same sort of geometry.
LongRat
www.fulloption.co.uk
i seeing it has tapers and threads..
if it were mine, i would start off a square material... drilling centers on mill and make diameters between centers..
i guessing it is part of a type of crankshaft.. a pump?
Looks like a Harley crank cross pin. And he's trying to increase the stroke.
I would use something like 4140 pre-hard or B3X. How are you going to keep the offset from turning? Even with the tapers and threads this is not a good way to stroke a built up crank.
Most of them are done by boring the pin holes over size and plugging them, then re-cutting the pin holes in what ever offset you are using. That way you can use a stock cross pin.
