588,533 active members*
8,825 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > macro - motion pauses each loop
    Jun 2006
    247
    I'm trying to get a macro working that mills a helical bore
    I've wrote it with two different methods, and the motion still pauses at the end of each loop
    each loop being the next helical move incrementally down in Z
    The call looks like this:
    G65 P9012 X0 Y0 Z1. D2. R0. T.5 Q.1 F10.
    X,Y = center of bore
    Z = depth
    D = diameter
    R = top of bore
    T = tool diameter
    Q = depth increment
    F = feedrate
    the first method uses a subroutine and L count:
    Code:
    O09012
    #26= ABS[ #26 ]
    #100= ROUND[ #26 / #17 ]
    IF [ #100 LT [ #26 / #17 ] ] THEN #100= #100 + 1
    #101= #26 / #100
    #102= 0 - #101
    #103= 1
    #104= [ #7 / 2 ] - [ #20 / 2 ]
    G00 X#24 Y#25
    Y [ #25 + #104 ]
    Z [ #18 + 0.1 ]
    G03 I#104 Z#18 F#9
    M97 P1000 L#100
    G03 I#104 F#9
    G00 Y#25 Z [ #18 + 0.1 ]
    M30
    N1000
    G91
    G03 I#104 Z#102 F#9
    G90
    M99
    the second uses an IF loop with a counter variable:
    Code:
    O09012
    #26 = ABS[ #26 ]
    #100 = ROUND [ #26 / #17 ]
    IF[#100 LT [ #26 / #17 ] ] THEN #100 = #100 + 1
    #101 = #26 / #100
    #102 = 0 - #101
    #103 = 1
    #104 = [ #7 / 2 ] - [ #20 / 2 ]
    G00 X#24 Y#25
    Y [ #25 + #104 ]
    Z [ #18 + 0.1]
    G2 I#104 Z#18 F#9
    N1
    IF [ #103 GT #100 ] GOTO 75
    G2 I#104 Z#102 F#9
    #102 = #102 - #101
    #103 = #103 + 1
    GOTO 1
    N75
    G2 I#104 F#9
    M30
    anybody got some help for me?
    it'd be much appreciated
    Jul 2005
    12177
    Why did you write a macro for helical motion when Haas has this capacity in G02 and G03?
    G91 G03 I0. J-j.j Z-z.z L10
    Gives you ten circles of radius j.j going down a distance of z.z for each circle for a total depth of 10z.z.
    G90 G03 I0. J-j.j L1
    Takes the helical ramp out at the bottom (the L1 is actually redundant).
    Jun 2006
    247
    'cuz I wanna
    no seriously,
    I convert a lot of programs from my Tree machine w/ A2100 controller and it has a circular pocket canned cycle G26
    So I'm gonna alias this macro to G26 in the Haas and set up the variables to be as close to the tree configuration as possible, thereby eliminating as much editing as possible.
    Besides that, its quicker and easier type in the diameter and depth than it is to figure the J value and Z / L.
    I try to do stuff like this to make programming at the machine as quick and error - proof as possible - for me and the guys I train.
    Plus this macro is gonna evolve:
    It'll have a finish pass for one, with arc on and arc off
    it'll also have cycle types such as:
    -rough and finish each increment
    -rough each increment and finish at final depth
    -helical entry
    -pre-drilled hole entry
  1. Spiral tool path from two circular motions
    By seapeace in forum Mastercam
    Last Post: 06-25-2008, 11:58 PM
  2. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  3. Macro WHILE DO END Loop (Lathe)
    By Jorge-D-Fuentes in forum G-Code Programing
    Last Post: 07-25-2007, 02:57 PM
  4. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
  5. Unusually long pauses
    By NeoMoses in forum DNC Problems and Solutions
    Last Post: 04-25-2003, 10:31 PM
