587,762 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Macro problem with Haas VF-1 and HS-1
Results 1 to 7 of 7
    Jul 2009
    86
    Question Macro problem with Haas VF-1 and HS-1
    Hello everyone,
    I'm having some problems and am hoping someone could shed some light. I will start off with what I am trying to accomplish:
    I am trying to write a program such that the machine will execute a courtesy line (returning the table to in front of the machine doors) ONLY when optional stop is activated. This would be for set-up purposes only so I can inspect/measure the part after each operation during the first setup WITHOUT manually jogging the table back to the doors after the M01 commands are read.
    Below is the program I have come up with so far, I have excluded the actual machining for simplicity but it demonstrates my idea pritty well:
    O0001 (MACRO TEST)
    N1 (MACHINING OPERATION 1)
    T1 M06
    S1000 M03
    <MACHINING CODE HERE>
    G91 G28 Z0.
    IF [ #3033 EQ 1.0 ] GOTO100
    N10 M01
    N2 (MACHINING OPERATION 2)
    T2 M06
    S500 M03
    G91 G28 Z0.
    M30
    N100 (TABLE RETURN)
    G91 G28 Y0.
    G91 G28 X12.
    GOTO10
    But now the headache haha,
    I have run this program on a HAAS simulator and it works flawlessly which is great! However, the shop floor is a different story. The Newer VF-1 I have access to does not have the Macro option enabled so that machine wont work. But I do have access to an older VF-1 and HS-1 Horizontal with the Macros enabled . But in the older machines the system variable #3033 (op stop) does not work. I get an "Illegal Macro Variable ALARM".
    I am wondering if anyone knows what the variable for optional stop would be on these older machines? Or how I could find out? I'd really like to give this a try!
    Or when push comes to shove if anyone could suggest a better way of having the table center itself ONLY when op stop is pressed it would be greatly appreciated.
    Thanks,
    Colton M.
    Nov 2007
    1702
    Why not just do block delete with the machine coordinates you want?
    Code:
    /G53 X-10.0 Y0.0 Z0.0
    /M00
    (Flip part over, then push the green button, dummy)
    Greg
    Jul 2009
    86
    Quote Originally Posted by Donkey Hotey View Post
    Code:
    /M00
    Three reasons:
    1. I am using a block delete on all the M08 coolant commands to avoid soakage while the door is open when proving the program. But when I actually let the part run for the first time I wouldn't want the coolant to be skipped.
    2. I am trying to link this table courtesy motion directly to the op stop button being pressed or not. Just for ultimate set-up efficiency.
    3. I'm learning all this in school right now and it would be much more satisfying to make it work than to find a way around it I'm paying them, they aren't paying me... Yet
    Thanks for the suggestion though.
    - C
    Nov 2007
    188
    M01 Macro
    You could right a 9000 program and call it from a M code and in the 9000 program have your move to the doors them a M00 or M01 then it would return back to your main program
    Mar 2003
    2932
    According to the manual there is no system variable for the optional stop switch on the older controls. The system variables stop at #3006.
    Feb 2010
    Run a sub program with a macro call out via m97 or g65 and the sub program sends it home then you just need a #xx=1do 1, elsedo2
    Sep 2005
    19
    This syntax doesn't look right.
    try
    IF[#3033EQ1]GOTO100
    Here is something else to think about, it is a macro used for a automatic door, maybe it will help.
    O0001 (MACRO TEST)
    T1 M06
    S1000 M03
    G91 G28 Z0.
    M98P8998(DOOR OPEN)
    M01
    T2 M06
    S500 M03
    G91 G28 Z0.
    M30
    O8998(DOOR OPEN)
    (DOOR OPEN MACRO.NC)
    N1(CONFIRM STATUS)
    IF[#109EQ1]GOTO3
    IF[#109EQ2]GOTO2
    #109=#108(SET 1=OPEN 0=RUN)
    M99
    N2(DOOR OPEN #109=1)
    M5
    M85
    #108=1(OPEN DOOR UNTIL #109=1)
    M99
    N3(DOOR OPEN #109=0)
    M5
    M85
    #108=0(OPEN DOOR ONCE)
    M99
    Good luck.
  1. Soliciting Haas Macro Advice
    By mcmachining in forum G-Code Programing
    Last Post: 07-28-2009, 06:07 PM
  2. Short macro problem
    By scrapper400 in forum G-Code Programing
    Last Post: 12-05-2008, 02:56 PM
  3. Drill Macro problem
    By toolmanwaz in forum CamSoft Products
    Last Post: 04-01-2008, 04:47 PM
  4. VF0E Macro Problem
    By stang5197 in forum Haas Mills
    Last Post: 06-14-2007, 11:34 PM
  5. Haas Vf-2,macro For Tool Life
    By Tulak in forum Haas Mills
    Last Post: 10-22-2004, 03:06 PM
