587,801 active members*
3,577 visitors online*
IndustryArena Forum > CAM Software > MadCAM > MadCam to Probotix CNC 4th Axis Post Processor
    Feb 2022
    Hello All!
    I am working on getting a 4th axis setup on our Probotix CNC. I have been having troubles with getting our post processor to work but it is at a point now where it seems to do everything it needs to be except I don't know how to make it run G93. Now I don't know anything really about writing post processors, coding syntax, or anything like that so I may be missing something obvious, but any help would be greatly appreciated!
    Here is the post-processor I have been working on:
    //MadCAM_POST_2003-12-10
    *VERSION*
    1.0_031210
    *FILE_NAME*
    Iso_G-code
    *FILE_EXTENSION*
    ngc
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.001
    *OUTPUT_WIDTH*
    4
    *OUTPUT_DECIMALS*
    5
    *SCALE_X*
    *SCALE_Y*
    *SCALE_Z*
    *SCALE_4*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *AXIS_4_CHAR*
    A
    *CUTTER_REFERENCE*
    TIP
    *TOOLPATH_OUTPUT*
    TRANSFORM
    *ANGLE_OUTPUT*
    CONTINUOUS
    *INVERSE_TIME_FEED_MAX*
    1000000
    *INVERSE_TIME_FEED_ON*
    G93
    *INVERSE_TIME_FEED_OFF*
    G94
    *RAPID_FEED*
    10000
    Or if there are any other workarounds let me know, thanks again!
    Feb 2006
    183
    Re: MadCam to Probotix CNC 4th Axis Post Processor
    Just use the variables for inverse time feed on and off for the first cut and last cut sections. See example below.
    //MadCAM_POST_PROCESSOR
    *VERSION*
    6.0_200202
    *FILE_NAME*
    Mach3_4-axis
    *FILE_EXTENSION*
    txt
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.005
    *OUTPUT_WIDTH*
    4
    *OUTPUT_DECIMALS*
    3
    *SCALE_1*
    *SCALE_2*
    *SCALE_3*
    *SCALE_4*
    *SCALE_5*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *AXIS_4_CHAR*
    A
    *AXIS_5_CHAR*
    B
    *CUTTER_REFERENCE*
    TIP
    *TOOLPATH_OUTPUT*
    TRANSFORM
    1000000
    G93
    G94
    *RAPID*
    G00"x""y""z""a"
    *END_SECTION*
    *RAPID_APPROACH*
    "x""y""z""a"
    *END_SECTION*
    *RAPID_RETRACT*
    G00"x""y""z""a"
    *END_SECTION*
    *APPROACH*
    G01"x""y""z""a" F"feedz"
    *END_SECTION*
    *FIRST_CUT*
    G01 "inverse_time_feed_on" "x""y""z""a" F"feed"
    *END_SECTION*
    *LAST_CUT*
    G01"x""y""z""a" F"feed"
    "inverse_time_feed_off"
    *END_SECTION*
    *CUT*
    *END_SECTION*
    *TOOL_CHANGE*
    ("toolname")
    M6 T"toolnr"
    M03 S"speed"
    *END_SECTION*
    *TOOL_STOP*
    M5 M9
    *END_SECTION*
    *TOOLPATH_CHANGE*
    (Toolpath change to "method")
    G00 "zhome"
    (Tool "toolnr" Continue's)
    *END_SECTION*
    *PROGRAM_START*
    G00 G49 G17 G80 G50 G90 G64 G94
    *END_SECTION*
    *PROGRAM_END*
    M30
    *END_SECTION*
    *LINE_START_NUMBER*
    /Joakim
  1. Replies: 1
    Last Post: 08-27-2020, 09:40 PM
  2. 4th axis post processor
    By danaramezani in forum PowerMILL
    Last Post: 03-05-2020, 04:13 AM
  3. 4th axis post processor
    By danaramezani in forum Fanuc
    Last Post: 02-07-2015, 09:47 AM
  4. Madcam/KMotion CNC Post Processor?
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-27-2013, 12:36 PM
  5. Fadal 4th axis post processor
    By Terrence in forum Fadal
    Last Post: 12-15-2008, 10:03 PM
