587,092 active members*
3,004 visitors online*
    Mar 2007
    30
    magnetic clamping
    hi
    does any one have idea about magnetic clamping for milling?
    dhiruj
    Mar 2006
    45
    I've got one on my macining center...
    it has it's pros and cons:
    Pros are obvious...
    Cons:
    Needs Surface area and thickness to achieve hold down ( small blocks won't stick)
    Chips stick to it, so if you're milling close to the bottom, the chips won't blow away with air, you'll start double cutting them...
    Overall i'm happy with it though... it serves it's purpose really well
  1. Magnetic Chuck for Milling Machine...?
    By tdfsu in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2007, 08:41 PM
  2. Fanuc Magnetic Sensor Error
    By symage in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2007, 11:02 PM
  3. Clamping Pressure
    By Team Pierson in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-12-2007, 08:08 PM
  4. CNC Retrofit A Heath/Torchmate Upright Magnetic Follower Shape Cutter
    By Weldtutor in forum Waterjet General Topics
    Last Post: 02-04-2007, 09:08 PM
  5. m32 alarm 27 magnetic position detect malf.
    By barebonzchop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-03-2006, 04:48 AM
