Hello guys
Can anybody help me?
My problem: The glass scale of the X axis doesn’t work properly when I run up to my work piece with the 3D scanner with the X axis, then zero it and go through the whole area with X and after go back to the same position. I have a discrepancy in X on the display, in the drill program even a discrepancy of 0.2mm from the required dimension.
The other axis are correct to 100/mm ,( no error message displayed)
Does anybody know if and how you can dismantle the glass scale. What all needs to be dismantled? Can you clean it?coangry.gif
How much does a new one costs and where would you buy it.
Many thanks in advance
With best regards Dubios
