603,844 active members*
4,680 visitors online*
    I am a new member and have a question regarding the RGB horizontal+ vertical signal on a Maho 800C( manufacturing year. 90) – screen.
    After switching the screen on, the picture on the CRT display is very blurred- only after around 1 / 2 hours the picture becomes more legible.
    When talking to Maho, they said that maybe the power supply unit might conk out soon.
    Now my question ( as a non electrician):
    We got a converter card from CGA to VGA ( to connect normal TFTs). With this card there is a connection cable, which is reserved with 6 cables.
    We should now connect the signal of the Maho with this cable.
    R G N horizontal vertical and mass.
    However the 15-pole SUB-S plug of the Maho has
    Blue, white, yellow, green, rose, brown and mass (so 7 cables)
    Can anybody tell me what cable has which signal?
    Many thanks for all your answers!!
    Regards
    MH800C_2011
    Hello
    The signals and wire colors are described in the circuit diagram of the machine.
    Good Luck!!
    Regards mtronik
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Hello
    I have found the page of the circuit diagram.
    Unfortunately, only the colors are described. Is there a RGB VH allocation for them?
    Regards
    Maho800C_2011
