586,061 active members*
4,602 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > MAHO MH 300 C doesn't respond (Matrix monitor)
    Jun 2021
    Hi
    Just bought me a MAHO MH 300 C that worked when it was loaded at the seller but when I unloaded it, plugged it in then it didn't respond to any inputs, the screen showed matrix-like pixels and the hydraulic won't start.
    Does anyone have a clue on what can be the problem?
    I've checked all the fuses (I think) and cables, disassemble the controll and checked the wires, found no problem there.
    Philips 432
    This is my first CNC machine, bought for learning so i'm quite new to this
    Attached Files Attached Files
    Jun 2021
    Re: MAHO MH 300 C doesn't respond (Matrix monitor)
    Anyone have any suggestion on what I can check, I have no clue on what the probleme could be.
    Can it be some glass fuse on some board that could couse this problem that I could have missed?
    I tried change the phases several times with no results.
  1. Mach3. Motor Tuning doesn’t respond
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 04-04-2020, 01:17 PM
  2. Deckel maho DMC 63V : Management tools not ready: data server MMC does not respond
    By azerty002 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-15-2017, 12:24 PM
  3. X-Axis doesn't respond to G-Code
    By WickedCNC in forum Chinese Machines
    Last Post: 06-23-2015, 04:31 AM
  4. Mach3 Jog doesn't respond using X-Keys
    By Dean448 in forum Mach Software (ArtSoft software)
    Last Post: 04-10-2010, 10:03 PM
  5. HELP! DeskCNC X-axis doesn't respond.
    By curtb in forum Mini Lathe
    Last Post: 04-21-2009, 02:09 PM
