Hello all
I'm slowly converting a small engine lathe to NC and have just completed the Z-Axis. The problem I'm seeing is that when the two 203V's are powered, the radio in the shop goes all static.
When the control (c11g) is on and everything else is powered up it's fine, only when I enable the drives (they are on a separate switch).
I through a ferite ring onto the main (120v) wire from the wall to no affect.
Should I look at the power-supply to gecko or gecko to motor (actually it does that without the motor connected so I guess that's out.
Anyways, performance is ok but the static on the radio has got to go.
Any ideas?
Mooser
