603,344 active members*
3,631 visitors online*
Results 1 to 10 of 10
    Jan 2006
    2985
    making an arc
    i have read up on all the code for making an arc but everything I have seen uses R or I J K in the code. I see no way on my MDI to input an R. What am I missing?
    Thanks for any help
    Matt
    Oct 2003
    263
    I think the Bridgeport control was limited to IJK to define arc centers.
    Software For Metalworking
    http://closetolerancesoftware.com
    Jan 2006
    2985
    so then do i use the x y z buttons again as the i j k. there are no i j k buttons so i guess that would have to be it. i will go try and report back.
    Matt
    Jan 2006
    2985
    doesn't work. here is what I was trying
    G17 (XY axis) G02 (cw arc) x.xxx y.yyy (endpoint) x.xxx (for I) y.yyy (for J)
    can anyone point me in the right direction?
    Matt
    Oct 2003
    263
    Did you give it a feedrate?
    Jan 2006
    2985
    i didn't explicitly give that block a feedrate but i had a feedrate set prior to that block. g2 and 3 work similar to g1 where it uses the last specified feedrate if one is not specified for that block correct?
    i can try giving it a feedrate in the same line tomorrow after work.
    Thanks for helping
    Matt
    Dec 2005
    30
    Example line from a program for Arc
    N20G3X****Y****I****J****F100
    The X,Y,Z and N keypad doubles up as the I,J,K and T.
    The above works on Boss 5
    Good Luck
    Dave
    Jan 2006
    2985
    so you are saying
    N20G3X****Y****X****Y****F100
    should get me an arc?
    i'll try it tonight.
    THanks for the help
    Matt
    Jan 2006
    2985
    i'm cutting arcs! thanks for all the help. turns out what works is this:
    G02 Xx.xxx Yy.yyy XX(I)i.iii YY(J)j.jjj Fff
    Matt
    Apr 2005
    17
    to use "I" on that control you would press the "x" button twice and the machine will change it to a "I" on its own like for instance if you ar using a "j" value type the "y" button twice and the machine will know that you are entering a "j" value (that is a bridgeprt textron control its old school but its accurate)
