603,386 active members*
3,263 visitors online*
    Mar 2006
    4
    Making a Edgecam postproc.
    Hello..
    I am making a postproc. for a heidenhein ITNC 530. It is used on a Hermle C30U 5ax
    Are there enyone who knows where i can find out what commands i can use in my post proc.??
    ;CODE:#USER8=0
    ;CODE:%IF #USER8=0 @TEST
    #MACRO=0
    ETC...
    And what are macros??
    And how I can get it to make cord every time instead of sub. cords (LBL) after drill cycles even i choose controller instead of pathtrace in the drill cylce
    Feb 2006
    3
    this post is not complet yet for the 4th and 5th axis but will give you most of the basic of the 3 axis and the cycles you will need have a look
    Attached Files Attached Files
