603,802 active members*
2,878 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Making an oddball Homag spindle useable?
Results 1 to 7 of 7
    Dec 2003
    199
    I have a Homag HF spindle that has an oddball shank on it.
    Suggestions on how I might make this a useable router spindle?
    As you can see in the pics, the shaft is a weird diameter. Doesn't seem to be a nice round number either imperial or metric.
    I was considering having a custom made sleeve made that would chuck onto the end of the shaft and have the "business end" bored for 1/2 inch router bits.
    Any ideas here?
    Spindle runs great and it looks like it's easy to replace bearings etc...
    Thanks in advance chip makers!
    Is a sentance fragment?
    Apr 2004
    5950
    Re: Making an oddball Homag spindle useable?
    What's the diameter and pitch on the threaded end? You might be able to screw a collet chuck on there, or make an adapter to facilitate that.
    Andrew Werby
    Website
    Aug 2005
    206
    You might do well to look at the volts. Looks like it might have seen service as an edge bander trim station. You might end up spending more to make it work then to buy a new Chinese made spindle.
    Dec 2003
    199
    I've got it hooked to a VFD and it runs great.
    Dec 2003
    199
    The treaded part is M10 1.5
    Thanks!
    Apr 2004
    5950
    Maybe one of these would work, if you made up an internally threaded sleeve to attach it: https://www.mscdirect.com/product/de...rItem=30717417
    Andrew Werby
    Website
    Dec 2003
    199
    Any thoughts about turning down the shaft on the spindle by running it while using and grinder mounted on a spare linear stage?
    Kinda like a tool post grinder.
  1. Converting a Sherline Mill to Mach3 with oddball drivers.
    By ruckusnuts in forum Stepper Motors / Drives
    Last Post: 11-22-2019, 06:12 PM
  2. Oddball stepper question - auto-focuser
    By Rhodan in forum CNC Machine Related Electronics
    Last Post: 11-11-2009, 09:07 PM
  3. Is this useable?
    By otomoton in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-27-2009, 10:35 PM
  4. Useable Router Spindle?
    By 2_many_hobbies in forum Benchtop Machines
    Last Post: 05-24-2009, 10:06 PM
  5. Useable or useless spindle?
    By andy_ck87028 in forum DIY CNC Router Table Machines
    Last Post: 07-30-2007, 04:03 AM
