603,383 active members*
3,324 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > making a table leg
Results 1 to 11 of 11
    May 2005
    31
    making a table leg
    OK I have two offset rectangles(0,0,0-1.25,1.25,0 and 0,0,17-2,2,17) that I drew lines to connect the corners. How do I join the lines with the rectangles to make a solid?
    Apr 2003
    470
    Select both rectangles...
    Surface > Loft > (hit enter)
    Select the surface that you just created....
    Solid > Cap Planar holes
    Done.
    Nathan
    May 2005
    31
    Thank You I have been puling my hair out with the Rhino commands. I like the program for 3d that is for sure.
    Apr 2003
    1361
    Hi Mikejkd,
    Do you have any tutorials for Rhino? This was a pretty basic question, which leads me to believe you are struggling with Rhino. The tutorials would help a lot.
    If you have a fast connection, I could e-mail level 1 to you (10Mb) if you wish.
    Dan
    May 2005
    31
    I do not even know where to get the tutorials. I would like to take you up on the offer for level 1. [email protected]
    Apr 2003
    1361
    Check you inbox. The zipped files are on their way.
    Dan
    Oct 2004
    727
    Another request for tutorial(s)
    Dan,
    I am also trying to learn Rhino3D and a basic tutorial would be a tremendous help. Do you have a link to the tutorial files that can be accessed or do you have to email them? My email is [email protected]. Any help is greatly appreciated!
    Thanks,
    Harry
    Apr 2003
    1361
    Hi Harry,
    Check your inbox too. I can't remember where I found these, so it would be a lot quicker if I just send them to you.
    Dan
    Apr 2003
    1361
    Found the source
    These tutorials that I have are on your Rhino installation CD under "Training Material".
    Dan
    Oct 2004
    727
    Rhino3D tutorials = Fantastic
    Dan,
    Thanks for the Rhino3D tutorial! The Rhino team did a fantastic job of reducing the learning curve from mountainous proportions to nothing more than a series of small hills that build on each other. Rhino3D is powerful stuff.
    My eyes are still open after the Level 1 training marathon, so... if I could impose on you for the Level 2 tutorial you would earn my undying gratitude.
    I'm currently using the Rhino3D Trial version and promised myself that I wouldn't purchase the full version until I learned how to use the software. Thanks to you I'm halfway there! I (and probably many others) have too many software titles that were purchased with every intention of learning how to use only to find out that they really weren't designed to do what I wanted, lacked adequate documentation, crashed while saving projects, etc. So far, Rhino3D seems to be worth my hard-earned dollars.
    Thanks again,
    Harry
    ([email protected])
    Apr 2003
    1361
    Hi Harry,
    Check your in-box. Level 2 should be there. Don't forget to join us on the Rhino newsgroup. You can get any questions answered 24/7.
    news.rhino3d.com
    You can access this with Outlook Express, or Mozilla Thunderbird.
    Dan
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. 5th even 6th axis? how does it work
    By ToMMY2ooo in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2004, 09:58 PM
  3. Making a model from a table of offsets?
    By fyffe555 in forum Rhino 3D
    Last Post: 06-30-2004, 08:48 PM
  4. Sanity check- 6'x10' table
    By Zephrant in forum DNC Problems and Solutions
    Last Post: 05-13-2003, 05:09 PM
