587,129 active members*
3,187 visitors online*
Results 1 to 4 of 4
    Jun 2013
    43
    Manual lubrication question
    I have a Acctek 4x8. It has the typical 2 oil containers one on each side of the gantry. On one side, when you push the lever down, it has vacuum to it and slowly raises back. the other side, has just the opposite, more pressure when you push down and then lifts back automatically. I am not getting any lubrication on the right side of the Y axis or on the X axis. 2 pumps of the right side pump and oil starts dripping out of my Z onto the table. I am trying to trace the tubes to see which pump oils what. All that I know for sure is that the right pump oils the Z. The pump on the right has the line going to the inside of the gantry so I can't really trace it to see which one goes to the axis that are dry.
    When I remove the tube from each container, they both will push oil out of the opening. I found the control valve for the Z axis and tried shutting off those to see if that would allow oil to make it to the other axis but had no luck. What is the proper way to adjust the screws for proper oiling? I don't want it dripping all over my work area. Anyone have the same brand of CNC and know how they plumbed them? Is there a bleeding process that I need to perform possibly?
    Any information would be appreciated. Tried looking it up online but am just find videos of how to push the lever down twice which doesn't help.
    Re: Manual lubrication question
    I think you can upload some photos, then It will be more clear.
    --Jinan UnionTech Machinery Co., Ltd.---
    Nov 2013
    152
    I had covers off mine yesterday. There are little manifolds with adjuster screws. I had a dry line. It wasn’t getting oil because the upstream screws were opened up too much. I had to trace it all out.
    Jun 2013
    43
    I finally got around to addressing my issue. $10-15 and about 2 hours of work and I changed out all the fittings on the bearings to grease zerks and now it runs great and no oil leaking on my parts. Wish I had done it long ago. You can go from oil to grease in the bearings just not grease to oil.
  1. Question About BP EZ Trak Lubrication System
    By talvare in forum Bridgeport / Hardinge Mills
    Last Post: 02-18-2015, 11:24 PM
  2. Manual to CNC First Step Question
    By Art99 in forum Mini Lathe
    Last Post: 06-15-2011, 06:59 PM
  3. lubrication question????
    By Cutloose in forum Linear and Rotary Motion
    Last Post: 10-14-2006, 09:20 AM
  4. Mill/Drill lubrication question??
    By elalto in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2004, 07:47 PM
  5. Manual Question
    By redneck_AR in forum Mastercam
    Last Post: 07-21-2003, 03:32 AM
