603,386 active members*
3,061 visitors online*
Results 1 to 6 of 6
    Feb 2005
    11
    Manual Puls Generator
    where to buy Manual Puls Generator for Mill Remote(Jog)??
    Sep 2003
    552
    http://www.nemicon.co.jp/en/product/index.html
    Check out the UFO and UFO-mini MPG's.
    Darek
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2003
    552
    I am surprised that US Digital with all there encoder offerings do not make a MPG.
    Darek
    Dec 2005
    3319
    Check out Red Lion. They have quadrature encoders and other MPG's that are used for making measuring equipment. One should easily be able to adapt them to hand operation for MPG.
    You can also use a 555 to make a "one shot" to index a click at a time.
    You can also set up a 555 as an astable multivibrator and feed it to a two input AND chip. Some simple push buttons and some pull down resistors would enable the outputs to provide FWD and REV direction commands in faster, continuous move mode.
    It all depends how fancy you want to get and how much electronics you know/want to learn as to how to go about doing what you want to do.
    Jan 2007
    3
    Hi There
    Does anybody know of a UK supplier for MPG's?
