603,310 active members*
2,567 visitors online*
IndustryArena Forum > Other Machines > Machine Created Art > Marble fireplace from a single stone ?
Results 1 to 7 of 7
    Oct 2018
    12
    This fireplace clearly having been constructed from several pieces of hand carved marble, can anybody confirm if such grand designs could be made from a single block of marble please ?
    Apr 2004
    5948
    Re: Marble fireplace from a single stone ?
    I suppose it's possible, but there was a reason the original makers did it the way they did. Just handling, shipping and installing such an extended piece of fragile stone would be a big nightmare. What would be the point?
    Andrew Werby
    Website
    Oct 2018
    12
    Quote Originally Posted by awerby View Post
    An uninterrupted design, which would clearly be an upgrade from the original.
    Apr 2004
    5948
    Good luck with that. Better make a few while you're at it, to allow for breakage in transit.
    Andrew Werby
    Website
    Oct 2018
    12
    I imagine the failure rate working with a metal like aluminium, compared to natural rock comprised of minerals like marble, is a lot less and so it does make sense, but what techniques can be used to bring that probability to alignment ?
    Perhaps slower passes ?
    Aug 2023
    3
    I think it can be done from a solid block, but it will cost you a fortune.
    Jul 2023
    I also asked this question when I was renovating my house. I knew they can do it, but the upfront cost bites for a solid block of marble and to turn it into a fireplace. So, if you are ready to pay it's up to you!Gladly, marble is no longer just a luxury item. Nowadays, there are plenty of artificial alternatives that are just as durable and elegant as real marble. So, when I've been renovating my home, I must say the appeal of marble floors and a marble fireplace is tough to ignore. While exploring my options, I discovered an artificial marble manufacturer and decided to give it a try. Basically, they've played a crucial role in helping me realize my vision without hitting my budget hard and sacrificing the quality.
  1. 3015 marble/quartz/stone cnc machining center
    By BlueElephantCNC in forum Videos
    Last Post: 06-20-2020, 03:35 AM
  2. light stone/marble/granite cnc router MT-C6015/MT-C1325
    By mornlift in forum News Announcements
    Last Post: 12-13-2012, 09:55 AM
  3. Spindle advice for marble and stone
    By mugabe in forum Glass, Plastic and Stone
    Last Post: 06-02-2007, 06:50 PM
