603,900 active members*
4,530 visitors online*
Results 1 to 6 of 6
    Nov 2006
    4
    Mark Century 2000 Dnc Problem
    Dear Friends!
    We have Churchill cnc lathe with Mark Century 200o control.
    We want to send G-Code with DNC !
    Can you help us? We need the RS232 cbling detail and DNC program.
    Nov 2006
    31
    I have some old stuff from when I worked for Churchill; not sure if I have the RS232 details, I will have a look. I do have the progamming books.
    Aug 2006
    16
    Hello Ozgurm
    If you find solution, share it wit us , please. Wiring and parameter detail's. Thanks
    Aug 2006
    38
    If you don't already have DNC software, you can download iWorkshop CNC File Transfer from http://www.iworkshop.co.uk
    On the CNC control there are a couple of parameters for baud rate:
    LOAD BAUD RATE = 4 (1200)
    OUT BAUD RATE = 4 (1200)
    PROTOCOL = 0
    The controller requires a blank line before the first line "N10 (ID,PROG,1,NAME)"
    and #4 (EOT) at the end of each transmission, in practice sending multiple #4#4... is more reliable.
    Thes are the settings for the computer:
    BaudRate=1200
    StopBits=1
    DataBits=7
    Parity=Even
    FlowControl=Hardware
    InitString=
    TermString=#4#4#4#4#4#4#4#4#4#4
    The cable is as follows:
    2-3
    3-2
    4-5
    5-4
    6-20
    7-7
    20-6
    Hope this helps.
    Aug 2006
    16
    Thank you Andy
    I will try this ASAP and write result to you.
    Feb 2009
    10
    serial communications between GE mark century, and PC
    I am trying to get serial communications between a PC with surfcam, and a Mazak mill with a GE mark century 2000 controller. Does anyone know what the settings should be for communications, and perhaps the procedure on the machine side to download a file from the PC to the machine?
    I tried the circuit diagram for the serial connections for a tape reader, and built a cable. The pins I used were 2,3 ,7(signal gnd) ,5,20 shorted on the machine side.
    unfortunately I think I am missing part of the process / or I have made a mistake.
    I keep getting an error on the machine side when I try to load the program:
    2966: load/out terminated error opening device
    io status returned: file port already opened
    Any help would be greatly appreciated.
