Hi all,
First time I want to machine an image with mastercam art.
So I use new art base surface from image, then in import image height I use 2mm
X=400 and y=400 (because I want to machine the part in 400x400 mm stock ).
Later I use spline for the image I want to machine, second xform contour 2 mm, third flatten the outside and smooth the inside.
Then i use organic convex parabola of width 4 mm and height 4 mm.
And final I use toolpath art base surface using a tool to machine.
And my problem is that the tool is working on the air and does not machine the part. :drowning:
Can you please help me with that?
Thank you
